PbxConfigTool] is disconnected -> nothing in activity log
jwronken
recently we moved our 3CX instance from hosted to self-hosted which worked without isssue.
However, today I wanted to check the activity log in the management console and only see 1 line:
05/16/2022 10:44:29 AM - [EC100009]: External application [xxxxx:0/PbxConfigTool] is disconnected:
xxxx is our instance name
Any ideas how I can get the activity log back?
thanks
Jan
Hmm.. if you change the level from low to medium you get many more entries :)
Stupid, forgot that I had set it to low.
So, the only issue is the
Is that something I should/can take care of or it's just informational?
thanks
Is this the same time you ran through the configtool to restore your backup?
if yes, this is normal.
Reactions: jwronken
gmacinit
