Personal FQDN 3CX Hosted
Samuel Ma
New User
Hello
How can i set up my personal FQDN if my 3CX is Hosted with 3CX? I cant gind any option at the setup… tank you:)
You can not, 3CX hosted you have to use a 3CX FQDN
Reactions: Samuel Ma
Hi @Samuel Ma,
With 3CX Hosting you'll have to choose a 3CX FQDN, if you'd like custom FQDN, you'll need a PRO license and above and you'll need to self host.
Hi @Samuel Ma,
Hello Vasilis Thank you for your info:) so for the Connection of MS Teams the FQDN of the 3CX has to be the same as the Teams FQDN right? So if my 3CX has the Domian *company.3cx.ch* and the Teams FQDN is *teams.company.com* it wont work? :)
Hi @Samuel Ma,
No, it's not a hard requirement. They don't need to be the same.
I would suggest taking this one step at a time, first get 3CX set up the way you want it to be then start the teams integration.
Hi @Samuel Ma,
Hi Vasilis Thank you very much. Do i have to warch on a important step at the Teams setup? Because i already seted it up one time but i had issues with the sync of the SBC in Temas. We cloudnt make any outgoing calls or Internal Calls:/
There is only one different if the 3CX FQDN is the same as the Teams SBC FQDN.
In this case, Teams will contact your 3CX system on TCP port 5061.
If the FQDNs are different, Teams will contact your 3CX system on TCP port 5062.
This means that you will need to open this port on the Firewall between your 3CX and the Internet.
That is the only practical difference.
Hi Nick Thank you. So do i have to open the Port as well if my 3CX is Hosted in 3CX directly? My 3CX has the Domian *company.3cx.ch* and the Teams FQDN is *teams.company.com* it will work? Thx
If your 3CX system will be Hosted by 3CX, then we have you covered, yes, port 5062 TCP will be open for you.
Okei great thank you. So i installed everything exactly like in the manual but i can get any connection in teams. Only incoming calls are working in teams outgoing calls ar not possible.:(
Zexus
