Solved Phone not ringing in
dylanp1702
Forum User
I have spoken to a couple of people in the office who have guided me to come here and ask you for some help. I have a phone that does not ring while in the ring group, you can call the phone directly using the DDI or extension number this works without any issues, I have reprovisioned the phone however still does not ring, I have checked the status and also the queue status they are set to available and logged in. I am not sure what else I can do. Any help would be very much appreciated.
Kind Regards,
Dylan
You mention ring group and queues - two totally different setups. Which one is being used for this phone
If ring groups - under Extension - Forwarding rules is 'Accept calls from Ring Groups' ticked
Can you clarify, you speak about RG and Q for same extension, so is it member of RG or agent in Q.
if in Q like i suspect, surely you forgot to set extension available ansd loggedin
11252
Reactions: dylanp1702
Hello, thank you for your response this was actually not ticked thank you for this!
Was RG finally?
Thank you for your response. This is what
The phone is like the one in the screenshot
Sorry have not understood what was the right solution for you, settings were for RG or Q ?
The issue is now sorted. It was because the Accept calls from Ring Groups was not ticked. Thank you all for your responses.
Kind Regards,
Dylan
fcentral
