- Joined
- Aug 12, 2017
- Messages
- 287
- Reaction score
- 3
On my system on 1 of the extensions There is a Yealink T29G Phone… The issue is that the phone is not ringing… Either when someone dials the extension internally, through the digital receptionist, DID, or ring group… The T29G can make outgoing calls, and works fine.. I checked in the management portal, and the phone is listed on the system… The DND on the phone is off… I went into the Phone's firmware to verify the log in information, and it says registered… There are other IP Phones on that extension and All other phones on that extension rings, but the T29G. It did ring in the past without any issues, but now its not... I'm a bit stumped here is to why its not ringing.. My other issue is when I got the phone, that I couldn't auto provision the phone either and had to go into the phones firm ware to program it. Even when the phone was reset to factory default.. I also can't reboot the phone either through the management portal.. I'm also a bit stumped too as to why the phone wouldn't auto provision and why I can't reboot from the management portal.. This phone is a supported phone...
