phones using wrong provisioning url
treepio
My provisioning URL, as specified using the advanced settings, is using the correct internal ip, 10.10.10.x
In setting up the server, it initially was using 10.0.0.x, so in restoring the phone system on this new server, they all use a provisioning url with this wrong ip.
Is there any way to fix this, without a complete system restore?
found the solution to this issue. Changing between local ip and the server name in the settings causes it to reload using the correct internal ip
Reactions: AWS2P
you mean your running 3CX server is on IP 10.10.10.x and with a restore you got 10.0.0.x instead ?
hughesdouglas
