Solved phonesystem : a password is required
Helmut72
after installing 3CX with the Debain 10 image I found that root is spammed every 2 hours with:
3CX.mydomain : Jan 30 17:29:06 : phonesystem : a password is required ; TTY=unknown ; PWD=/var/lib/3cxpbx ; USER=root ; COMMAND=/usr/sbin/3CXPinningFileUpdate https://downloads-global.3cx.com/downloads/v180/debianupdate/buster.txt
Any tips?
Thank you!
Hi @Helmut72,
Where is this message from, the Sys log?
I don't know but it seems a scheduled task or so:
helmut@3CX:~$ sudo mail
Mail version 8.1.2 01/15/2001. Type ? for help.
"/var/mail/root": 194 messages 194 unread
>U 1 [email protected] Fri Jan 14 21:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 2 [email protected] Fri Jan 14 23:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 3 [email protected] Sat Jan 15 01:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 4 [email protected] Sat Jan 15 03:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 5 [email protected] Sat Jan 15 05:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 6 [email protected] Sat Jan 15 07:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 7 [email protected] Sat Jan 15 09:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 8 [email protected] Sat Jan 15 11:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 9 [email protected] Sat Jan 15 13:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 10 [email protected] Sat Jan 15 15:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 11 [email protected] Sat Jan 15 17:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 12 [email protected] Sat Jan 15 19:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 13 [email protected] Sat Jan 15 21:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 14 [email protected] Sat Jan 15 23:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 15 [email protected] Sun Jan 16 01:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 16 [email protected] Sun Jan 16 03:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 17 [email protected] Sun Jan 16 05:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 18 [email protected] Sun Jan 16 07:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 19 [email protected] Sun Jan 16 09:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 20 [email protected] Sun Jan 16 11:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 21 [email protected] Sun Jan 16 13:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 22 [email protected] Sun Jan 16 15:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 23 [email protected] Sun Jan 16 17:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 24 [email protected] Sun Jan 16 19:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 25 [email protected] Sun Jan 16 21:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 26 [email protected] Sun Jan 16 23:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 27 [email protected] Mon Jan 17 01:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 28 [email protected] Mon Jan 17 03:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 29 [email protected] Mon Jan 17 05:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 30 [email protected] Mon Jan 17 07:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 31 [email protected] Mon Jan 17 09:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 32 [email protected] Mon Jan 17 11:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 33 [email protected] Mon Jan 17 13:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 34 [email protected] Mon Jan 17 15:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 35 [email protected] Mon Jan 17 17:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 36 [email protected] Mon Jan 17 19:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 37 [email protected] Mon Jan 17 21:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 38 [email protected] Mon Jan 17 23:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 39 [email protected] Tue Jan 18 01:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 40 [email protected] Tue Jan 18 03:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 41 [email protected] Tue Jan 18 05:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 42 [email protected] Tue Jan 18 07:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 43 [email protected] Tue Jan 18 09:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 44 [email protected] Tue Jan 18 11:29 17/789 *** SECURITY information for 3CX.mydomain ***
U 45 [email protected] Tue Jan 18 13:29 17/789 *** SECURITY information for 3CX.mydomain ***
I checked crontabs but couldn't find anything.
From [email protected] Sun Jan 30 19:29:07 2022
X-Original-To: root
To: [email protected]
Auto-Submitted: auto-generated
Subject: *** SECURITY information for 3CX.mydomain ***
Date: Sun, 30 Jan 2022 19:29:06 +0100 (CET)
3CX.mydomain : Jan 30 19:29:06 : phonesystem : a password is required ; TTY=unknown ; PWD=/var/lib/3cxpbx ; USER=root ; COMMAND=/usr/sbin/3CXPinningFileUpdate https://downloads-global.3cx.com/downloads/v180/debianupdate/buster.txt
Hi @Helmut72,
Do you have "Automatically update 3CX" enabled under Settings >> Updates in the Management Console? I believe the message you're getting could be coming from the 'On Linux systems, this option also automatically installs Debian Security Updates.'
Yes, automatic updates are enabled.
But what confuses me is the "a password is required" message. Running the command manually does not cause an error:
[root@3CX ~]# /usr/sbin/3CXPinningFileUpdate https://downloads-global.3cx.com/downloads/v180/debianupdate/buster.txt
--2022-01-31 17:16:13-- https://downloads-global.3cx.com/downloads/v180/debianupdate/buster.txt
Resolving downloads-global.3cx.com (downloads-global.3cx.com)... 104.22.14.119, 104.22.15.119, 172.67.39.236, ...
Connecting to downloads-global.3cx.com (downloads-global.3cx.com)|104.22.14.119|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/plain]
Saving to: _/tmp/pinning.tmp_
/tmp/pinning.tmp [ <=> ] 24.41K --.-KB/s in 0.001s
2022-01-31 17:16:13 (20.2 MB/s) - _/tmp/pinning.tmp_ saved [24998]
Pin file downloaded
[root@3CX ~]#
Not sure what "phonesystem" is trying to do here.
The issue was that an entry in sudoers was missing:
phonesystem ALL=(ALL) NOPASSWD: /usr/sbin/3CXPinningFileUpdate
Reactions: VasilisV_3CX
Great find @Helmut72! Good job! If you require anything else, feel free to open a new thread.
Bluebox Global
