Solved PIN the Dialer or "Always on Top"?
SOTASOTA
SOHO User
Hello!
The Dialer looses focus when other windows are selected. Is there a way to make the Dialer "PIN" or stick as a "always on top"?
If for example I "Barge In" on a call, you hear the ringing of the extension, but the dialer is lost in a sea of windows.
Thanks,
Russ
Hi @SOTASOTA,
If you right click on the Desktop App icon in the system tray, you can select to keep it always on top:
Ah!!!!!!!!!!!!!!!!!!!!!!!!!
Brilliant!!!!!!!!!!!!!!!!!!
Cheers!
Russ
Reactions: VasilisV_3CX
Sure thing @SOTASOTA, feel free to open a new thread if you need anything else!
mazet
