Solved Pipedrive CRM Integration Template missing
Doomiix
Hi there,
I've accidentally deleted the Pipedrive-template in the integartion settings. Is there a way to add it back in? I alreday restored an older 3cx backup but it didn't solve the problem.
Thanks in advance for any help.
System: Version 20.0 Update 1 (Build 731 Release)
You should be able to download it again from the Updates page.
Reactions: Doomiix
There is no need to re-install.
Once you return to the CRM integrations section there must be an available update for you download again the template.
Reactions: Doomiix
Thanks for the quick response. It worked with downloading it via the Updates-Page.
tejohnson
