Placeing call on HOLD results in dialtone in handset
EzPCConcepts
SMB User
I am a newbie here and hope this is just an oversight on my part and may need new glasses. Have 3CX up and running and have for the most part configured 5 Snom SNO-D765 phones via SipTrunk services. I still have some things to figure out but am having an issue I did not expect. When I put a call oh HOLD via the hold button on the phone it started a new call and I hear a dial tone in the hand set. I had not manipulated any special settings other then those associated with the inital setup so I am thinking it might be something specific I have to change for the phone that I am using but when I access the codes section I have not found any reference to the hold key... thank you in advance for your time and assistance.
I found this thread while trying to answer the dial tone on hold mystery, so I hope it's acceptable to drift the thread back to its original subject. I had the same complaint about our Snom D785 phones playing dialtone when you have a call holding locally at your phone.
Some responses above suggested hanging up the receiver. All that you accomplish by doing that is that the speakerphone plays the dialtone louder. Pressing the speakerphone button in an attempt to hang up on the dialtone has no effect. Snom phones just do not like you to forget that you have someone on hold, I guess.
Our use case that makes this a problem is when a call comes in and the receptionist knows that I'm not at my desk, for example because she just saw me walk out of my office to consult a colleague. It's easier for her to find me in person to ask if I can take the call, before transferring it to me. The dialtone playing out loud that entire time is annoying and, if a client happens to be waiting in the reception area, it gives a slightly unprofessional appearance to how the phones work.
I found a setting in the Snom phone for this. Here is the documentation: https://service.snom.com/display/wiki/cw_dialtone
On the current 3CX-approved firmware for the D785, the setting can be found in the phone's web interface under Setup -> Advanced -> Audio -> Dialtone During Hold.
Turning that setting off gives the phone the same behavior except that it is silent, so you can hang up the receiver and not hear a loud dialtone while you do whatever you need to do before transferring or returning to the call.
Shared parking works for this scenario, but it is still nice to turn off that dialtone.
Now, the question is whether I need to set anything in 3CX to make the Snom setting persist.
I just picked up a D785 this week for initial testing, looking to replace an office full of Grandstream GXP-2170's with these SNOM devices. This strange dial-tone on hold behavior was the only thing I didn't like about the D785, otherwise seems like a really solid phone and works really well with 3CX out of the box.
As JohnS_3CX mentioned, this is standard for SNOM (albeit an odd default choice). If you manually change the setting on each phone via the web gui, I can confirm it will persist as the current 3CX template does not include this configuration item and therefore will not overwrite it.
Another option, if you have a lot of these to deploy would be to include the following line (as referenced by iamtheari at https://service.snom.com/display/wiki/cw_dialtone) in a custom template.
<cw_dialtone perm="PERMISSIONFLAGS">off</cw_dialtone>
It would be awesome if 3CX could include this line in their template (with 'off' value), as I think it's how most users would expect the phone to behave and more inline with other supported phones with 3CX.
Regarding Snom in specific, it is normal to hear the dial tone when you put a call on hold.
Like JohnS its the way the phone and PBX works.. I figured the logic is that when you hit the HOLD button you still need to send the call somewhere. I use the Park function for that purpose and it seems to work very well so far no complaints... yet?
carterloudermilk
