- Joined
- Dec 7, 2017
- Messages
- 70
- Reaction score
- 9
In this from the help:
Note that after the appointment has ended, the status of the extension will remain in state that it was automatically set to. This is due to the fact that meetings tend to take longer than scheduled. You will have to revert your extension status to “Available” manually, either by using the 3CX app, or using a provided dial code. The default dial code for “Available” is *30.
Any plans to change the status automatically back to Available after the event has ended? Or is there a way to make it happen?
Thanks!
Thanks!
