Solved Plantronics Hub doesn't show support for 3cx Softphone - will it work?
gigaboy
SOHO User
I have a Voyager 5200 wireless with Plantronics Hub software. There's a dropdown list of a number of clients, but 3cx is not listed (see screenshot and this urL: https://www.plantronics.com/us/en/support/supported-softphones.
In that absence, is there a preferred client that the existing selection that would give me best operability?
Hi @gigaboy
You can start by downloading the Plantronics Hub software version linked here:
https://www.3cx.com/docs/
Then run any updates that it may ask for, and reboot your system. Following the guide above, it instructs you to select the headset in the 3CX app.
After this you should be able to answer calls. The 3CX client does not show up in that list, but once detected it will show up under SDK (only while 3CX Windows app is running)
12555
Reactions: gigaboy
Roman Mazur
