Plugin disposal
Steve G.
I'm trying to cleanup when the main 3cx Windows Phone is exited.
I found the Attribute [CRMPluginDispose] and made the Plugin implementing IDisposable, but I have Trouble to get the Plugin notified when the main app closes.
How is main app notifying its Plugins about a shutdown?
Best regards
Steve
Hello @Steve G.
You don't need to implement IDisposable. You just add the attribute [CRMPluginDispose] to the method you want to be called on dispose.
Kind regards.
Reactions: VoIPTools
Hi @edossantos,
i tried that and it did not succeed. Also a breakpoint at this method does not halt, nor the log entry is written.
Code:
        [CRMPluginDispose]
        public void Dispose()
            ToLog("Disposing Plugin");
Plugin class signature:
Code:
 [CRMPluginLoader]
 public class W3cxPlugin : AbsCallNotifier{
        [CRMPluginInitializer]
        public static void Loader(IMyPhoneCallHandler callHandler){..}
Any idea what is missing?
Best regards,
Steve
Hello Steve,
That should work...
Is the Dispose method inside the class W3cxPlugin?
Also, you can try using a finalizer for the class:
Code:
~W3cxPlugin()
However, the finalizer might not be invoked at all by the .NET framework in some cases...
Kind regards.
Hello @Steve G.
Kind regards.
Hello Steve,
That should work...
Code:
~W3cxPlugin()
Kind regards.
yes it is inside but still it does not work.
However using the finalizer as suggested works fine.
We keep track on the Framework version and will retest this on Version change, so consider this solved.
Thank you'!
costionofrei
