Polycom VVX 400 (SoftKey Enablement)
Matt_NM
Howdy everyone,
I am attempting to enable a soft key to the conference line (7000) on a Polycom VVX 400. When adding to a template I cant seem to get it working, uploading the configuration directly to the phone works. Does anyone have ideas on how I can achieve this? Verfied through the phone webpage I can manually add a DND so I belive enhancedFeatureKeys.enable is working. Thanks in advanced for any help
##########################Modified_Working_CFG_Uploaded_2_Phone##########################
feature.enhancedFeatureKeys.enabled="1"
softkey.4.action="7000*0000$Cpause1$"
softkey.4.enable="1"
softkey.4.label="Conf"
softkey.4.use.idle="1"
softkey.1.enable="0"
##########################template_not_Working_on_3CX_Server##########################
</homeScreen.UCOne>
</homeScreen>
<homescreen>
<homescreen.intercom homescreen.intercom.enable="1">
</homescreen.intercom>
</homescreen>
<feature>
<feature.callPark feature.callPark.enabled="1"/>
<feature.directedCallPickup feature.directedCallPickup.enabled="1"/>
<feature.urlDialing feature.urlDialing.enabled="0"/>
<feature.enhancedFeatureKeys feature.enhancedFeatureKeys.enabled="1"/>
</feature>
<softkey
<softkey.4.enable="1"/>
<softkey.4.label="Conf"/>
<softkey.4.action="7000*0000$Cpause1$"/>
<!-- BLF Setup-->
<attendant
attendant.reg="1"
attendant.ringType="ringer1"
attendant.uri="">
<attendant.behaviors>
<attendant.behavior
Reactions: nub
I figured it out! Here is the code that worked for me, just in case someone else needs to do the same. This code will dial the conference line, enter our security pin and auto assigns the id by the user's extension.
<WEB
softkey.1.action="7000[%%extension_number%%]155889"
softkey.1.enable="1"
softkey.1.label="Conf"
softkey.1.use.idle="1"
Reactions: nub
3K8iMGWviZ
