Polycom VVX1500 support
3CXAdmin
Has anyone gotten the polycom vvx1500 to work with 3cx? There are not represented in the phone setup list. Is another phone compatible, or is there a download that will support this phone?
thanks,
GB
Closest supported model template sometimes works but this varies from level of support vendors and firmware versions.
thanks eddv123,
3CX doesn't have any models that are obviously similar, so I might try some that are pretty far off in model number.
If you are familiar with writing custom templates you could write your own. Have you contacted Polycom ? the vendors in some cases are responsible for writing these.
supuni_rathnayake
