poor call quality twilio trunk poor call quality inbound and outbound calls
michaelh76
I get echoing from my cellphone on tmobile and home phone when calling twilio trunks any suggestions
Echo is not typically a trunk issue, it's usually the device you are using.
Reactions: NickD_3CX
well I have tried a phone and webclient and get the same echo that is why I am confused. Do you have experiene with twilio and telnyx trunks? I am looking for a partner
I completely agree with cobaltit on this, echo is an "analog" symptom usually, caused by headsets, people using speakerphone, etc...
I would first try to rule out some cases to try and zero in on the problem by making a call between 2 extensions and checking if that has echo.
Generally though, you can find 3CX Partners from here:
https://www.3cx.com/ordering/find-reseller/
gmacinit
