Port 9150
liamkelly
Whenever I do the firewall test it fails on port 9150. I found out that this is due to us blocking TOR services which includes port 9150
What's this port used for on 3CX? As far as I know it's not caused any issues, but I just like to be sure and have everything green!
Thanks,
Liam
Thanks,
Liam
Hi Liam
Its one of your RTP ports, used for external extensions audio. You'd be pretty unlucky to hit this and have an issue but if you ever did run in to problems and have to raise a support case with 3CX, the first thing theyll ask you is if the firewall test passes.
Reactions: liamkelly
Hi Liam
Thank you :)
Wecare_ITA
