- Joined
- Oct 2, 2017
- Messages
- 55
- Reaction score
- 2
I am using a patton gateway with my 3cx deployment and am using two pots lines with it. One of my pots lines seems to be having higher voltage spikes than the other line causing the port its plugged into, to stop working after a couple days of use. After the port has been is use for a day or two, eventually a server error will appear on handsets when trying to use both lines simultaneously. I have came to the conclusion that the voltage spikes are maybe "frying" the ports? I am just curious as to if anyone else has ever run into this and has any recommendations. Are there any devices I can connect to my pots line to help regulate the voltage? Is this something that is better asked of Patton support or my phone provider (which they are telling me its on my end of course and there's nothing they can do).
