Solved Possible to restrict webclient password change?
jmatano
Platinum Partner
Is it possible to restrict the user from changing their webclient password? If not, is there a way to force password complexity.
I have imported users with a set password and we would like to keep so that the group manager can ensure they login. We would rather keep those passwords static, but if that is not possible, if they do change their password we would like it to have some sort of complexity.
Thanks in advance.
Hello @jmatano
Please note that there is no way to restrict the users from changing their password and the password complexity is hard-coded into the system and cannot be changed. This is currently set to 6 characters.The users will not be able to set a shorter character. If this does not meet your requirements i would suggest posting a feature request on our Ideas section of the forum https://www.3cx.com/community/forums/3cx-ideas/ . All posts are reviewed by their corresponding Departments and, if feasible and voted for by other users as well, may be implemented in an upcoming service pack or update.
Reactions: jmatano
Understood. Thank you for clarification and confirmation. You may close this thread.
Glad i could assist
Bluebox Global
