Pressing 0 (Zero) disconnects call
CoachWaker
SMB User
When I called a landline number in the Philippines from the windows app today and it asked me to press zero to connect, when I pressed zero I was disconnected every time, moreover there was no tone when I pressed zero. When I pressed the number one digit there was a tone I was not disconnected
Hello @CoachWaker
Does the same issue occur when you call the same number using the softphone or the Web Client?
Also, in the trunk options, try changing the codec priority/order and test whether the issue happens with the other codecs as well.
RJenkinsROCK
