prevent 3CX mobile app from provision while in same Lan with 3CX server
KhaledQuenawy
when any ext call another ext on ip phone it is annoying when 3CX app on mobile ring in same time ... imaging when you have more than 20 ext in same office and and coming call to ip phone make the app ring in same time ... How to prevent that .. i want to prevent app from provisiong to 3CX while using same wifi lan
The only way is to disable the account within the mobile app
Remember to enable when outside of the office
IFTTT would be the only hack to tell the device to don't do something if X occurs, such if WiFi SSID = Y then disable App Notification (to try as I am an iOS user)...
What is IFTTT and how to use it
bosdorf
