Prevent user from change his status
KhaledQuenawy
how to prevent user from changing his status
Hi Khaled,
This is a major part of how the system works and controls forwarding profiles.
You cannot stop a user from changing the status.
Is there maybe some other way to achieve what you want? What is the end goal you wish to do?
You can just fire him
Hi Khaled,
i want any call come to user in work hours whatever his status is
you can create replacement rules on his phone to prevent *3X and have them do *30 but if they use the 3cx app, they can change it there.
I think another way you can do it is to add a 2nd account/extension to their phone. have it forward to their extention instead of voicemail after 20 seconds, so that there is only one voicemail account, don't give it a line number and then send calls to it. I don't think they can change it then.
You can create a RG for this guy and on his ext tick "Accept calls from Ring Groups" under "Forwarding Rules"
[email protected].
