Solved Privacy: id Withheld Caller ID
antechs
We have an "unsupprted" sip trunk we use.
The provider has asked for the below value for withholding the caller ID to be passed to the VoIP provider.
They have referenced the below RFC3325 standard which uses a privacy type value.
Any ideas how I can get 3CX to do this?
https://www.ietf.org/rfc/rfc3325.txt
(Copied from above link section 9.3)
9.3 The "id" Privacy Type
This specification adds a new privacy type ("priv-value") to the
Privacy header, defined in [2]. The presence of this privacy type in
a Privacy header field indicates that the user would like the Network
Asserted Identity to be kept private with respect to SIP entities
outside the Trust Domain with which the user authenticated. Note
that a user requesting multiple types of privacy MUST include all of
the requested privacy types in its Privacy header field value.
priv-value = "id"
Example:
Privacy: id
Thanks in advance for any suggestions...
Glad to see you were able to overcome the issue
devo.it
