Solved Problem: Caller ID passing through 3CX from original caller to external number (Twilio)
JimNX
I've searched and search for a solution to this but cannot find a solution. There is a thread stickied at the top of this forum (Caller ID not passed through to external mobile) but it doesn't have a clear answer that works for me. In short, I am trying to pass the Caller ID information from the original caller, through 3CX, to an external number. No matter which combinations of setting I try, I cannot get it to work.
I'm using 3CX 18.0 Update 2 (Build 314) and Twilio as my provider. According to 3CX, Twilio is compatible with CLNS/Clip No Screening Support.
Things I have tried:
  • Forward to external number
    • Result in no outbound rule, if I create an outbound rule, Twilio rejects the call because I don't own the caller's number
    • "The caller-ID +15********* is unverified. SIP Trunking terminating calls to PSTN must use a valid Caller ID in the From Field. A Valid Caller ID is either a DID you have purchased from Twilio or a verified Caller ID."
    • Also results in "Redirect URI is not allowed. Redirect target: <sip:+15*********@************.sip.twilio.com:5060>"
  • Forward to mobile
    • Result in the office's number showing on Caller ID instead of the original caller's ID
  • Ring mobile simultaneously
    • Doesn't pass through if the dummy extension isn't registered to anything (typically set to DND or unregistered)
I've tried various combinations of Outbound Parameters in the SIP trunk settings as well. I have a support ticket submitted with Twilio and I'm waiting to hear back from them too. My customer is threatening to port his number to another carrier if I can't get forwarding to work properly. Please let me know if you know of anything I can try.
Reactions: jmelo22
Hello @JimNX
Unfortunately I do not have an answer for you at this time. We had other users that use Twilio report this lately but every time we try to replicate it on our accounts it always works. The solution so far was to change the outbound parameters to avoid calls from failing but not send the Originator caller id but this is not what you want. We are looking into this and if the issue persists we will need to remove support for CNS for Twilio.
Hi @YiannisH_3CX
Which settings are you using that work? I'll post exact configuration and logs here in a moment.
I called my customer's 3CX number (+131******69) from my office (+184******29). 3CX is configured to forward the call to an external number (+158******04). (either forward to mobile, external number, or call deflection)
-- 3CX configured to deflect call (302) to an external number --
From Twilio:
Code:
[ICODE]Properties
DEBUG EVENT SID NO39e39d9a15af2961e51489e5eabc5cff
SERVICE SID
RESOURCE SID CA639d4ed6b3f40b5a60d60af4dfa21670
TIMESTAMP 2022-01-25 20:46:27 UTC
MESSAGE
Redirect URI is not allowed. Redirect target: sip:+158******04@det**********ape.sip.twilio.com:5060
SIP: Redirect failed: Redirect URI is not allowed. Redirect target: sip:+158******04@det**********ape.sip.twilio.com:5060[/ICODE]
From 3CX:
[ICODE]01/25/2022 3:46:32 PM - CSTA: on info success: CSTA Recv 200/INFO from 68.**.**.129:5060 tid=5682a835b9676607 Call-ID=V0kzWZhCNAwym3cK3XQUOQ..:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 104.***.**.212:5060;branch=z9hG4bK-524287-1---5682a835b9676607;rport=5060
Contact: sip:2002@68.**.**.129:5060
To: sip:2002@68.**.**.129:5060;tag=2839261220
Call-ID: V0kzWZhCNAwym3cK3XQUOQ..
CSeq: 33837 INFO
Content-Type: application/csta+xml
User-Agent: Yealink SIP-T46S 66.84.0.125 805ec0cc144d
Content-Length: 235
01/25/2022 3:46:32 PM - CSTA: onReadyToSend: CSTA Send Req INFO from 0.0.0.0:0 tid=2cedaa0cc0887735 Call-ID=V0kzWZhCNAwym3cK3XQUOQ..:
INFO sip:2002@68.**.**.129:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---2cedaa0cc0887735;rport
Max-Forwards: 70
Contact: sip:2002@104.***.**.212:5060
CSeq: 33837 INFO
Content-Length: 216
01/25/2022 3:46:29 PM - Currently active calls [none]
01/25/2022 3:46:27 PM - Call(C:737): Incoming call has been deflected to sip:+158******04@det**********ape.sip.twilio.com:5060
01/25/2022 3:46:27 PM - [CM503008]: Call(C:737): Call is terminated
01/25/2022 3:46:27 PM - Blocking refers for the Call(C:737)
01/25/2022 3:46:27 PM - Call(C:737) is terminated
01/25/2022 3:46:27 PM - Leg L:737.1[Line:10002<<+184******29] is terminated: Cause: BYE from PBX
01/25/2022 3:46:27 PM - Terminated from "TOLL FREE CALL" sip:+184******29@det**********ape.pstn.twilio.com;tag=30617298_c3356d0b_a0746c6e-4718-4c7d-81e5-c20d77f8a6b0 to sip:+131******69@det*****now.my3cx.us;tag=80db3b78; reason: Referred
01/25/2022 3:46:27 PM - L:737.1[Line:10002<<+184******29] Sending: OnSendResp Send 302/INVITE from 0.0.0.0:0 tid=7174.10c4abb5e8ccf90913dc84cc9d47d322.0 [email protected]:
SIP/2.0 302 Moved Temporarily
Via: SIP/2.0/UDP 54.***.**.3:5060;branch=z9hG4bK7174.10c4abb5e8ccf90913dc84cc9d47d322.0
Via: SIP/2.0/UDP 172.**.**.239:5060;rport=5060;branch=z9hG4bKa0746c6e-4718-4c7d-81e5-c20d77f8a6b0_c3356d0b_46-14187181139406092035
Contact: sip:+158******04@det**********ape.sip.twilio.com:5060
To: sip:+131******69@det*****now.my3cx.us;tag=80db3b78
From: "TOLL FREE CALL" sip:+184******29@det**********ape.pstn.twilio.com;tag=30617298_c3356d0b_a0746c6e-4718-4c7d-81e5-c20d77f8a6b0
Call-ID: [email protected]
CSeq: 1 INVITE
Diversion: sip:+131******69@det*****now.my3cx.us
Content-Length: 0[/ICODE]
-- 3CX inbound rules configured to immediately forward the call to an external number --
From Twilio:
Warning - 32021 Carrier TIMESTAMP 2022-01-25 17:02:40 UTC MESSAGE Identity signature failed to be verified SHAKEN/STIR call verification failed: Identity signature failed to be verified
From 3CX:
Code:
[ICODE]01/25/2022 3:02:38 PM - [CM500002]: Call(C:721): Info on incoming INVITE from Line:10002<<+184******29:
Invite-IN Recv Req INVITE from 54.***.**.3:5060 tid=0ba5.7e79d13599c37a973c513ab4a4885b49.0 [email protected]:
INVITE sip:+131******69@det*****now.my3cx.us SIP/2.0
Via: SIP/2.0/UDP 54.***.**.3:5060;branch=z9hG4bK0ba5.7e79d13599c37a973c513ab4a4885b49.0
Via: SIP/2.0/UDP 172.**.**.127:5060;rport=5060;branch=z9hG4bKd40aad01-165c-4d49-af84-62d5c8a0d632_c3356d0b_87-189378194611092096
Max-Forwards: 63
Record-Route: sip:54.***.**.3;lr
Contact: "TOLL FREE CALL" sip:+184******29@172.**.**.127:5060;transport=udp
From: "TOLL FREE CALL" sip:+184******29@det**********ape.pstn.twilio.com;tag=78190731_c3356d0b_d40aad01-165c-4d49-af84-62d5c8a0d632
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY
Content-Type: application/sdp
User-Agent: Twilio Gateway
P-Asserted-Identity: "TOLL FREE CALL" sip:+184******29@nom***ech.sip.twilio.com:5060
Diversion: sip:+131******[email protected];reason=unconditional
X-Twilio-VerStat: TN-Validation-Passed-A
X-Twilio-AccountSid: AC*******************************fb3a
X-Twilio-CallSid: CA3efe863ec5f7a69bb97c0818a4257455
Content-Length: 275[/ICODE]
-- 3CX configured to forward the call to a mobile number assigned to an extension from which is unregistered ---
From Twilio:
(could not find entry in error log)
From 3CX:
Code:
[ICODE]01/25/2022 3:29:16 PM - Set log verbosity to MaxLevel = 2, Severity mask = 7
01/25/2022 3:29:15 PM - Dev(377183904):[sip:2002@68.**.**.129:5067 / 2002]: PBX contact is public IP: sip:2002@104.***.**.212:5060/UDP
01/25/2022 3:29:15 PM - Updating device Dev(377183904):[sip:2002@68.**.**.129:5067 / 2002] by message: DevUpd Recv Req REGISTER from 68.**.**.129:5067 tid=4254417950 [email protected]:
REGISTER sip:det*****now.my3cx.us:5060 SIP/2.0
Via: SIP/2.0/UDP 68.**.**.129:5067;branch=z9hG4bK4254417950
Max-Forwards: 70
Contact: sip:2002@68.**.**.129:5067
To: "Pr**********ape" sip:2002@det*****now.my3cx.us:5060
From: "Pr**********ape"sip:2002@det*****now.my3cx.us:5060;tag=1067881236
CSeq: 56370 REGISTER
Expires: 120
Allow: INVITE, INFO, PRACK, ACK, BYE, CANCEL, OPTIONS, NOTIFY, REGISTER, SUBSCRIBE, REFER, PUBLISH, UPDATE, MESSAGE
Proxy-Authorization: Digest username="b2dma73NF4",realm="3CXPhoneSystem",nonce="414d535961f05d9b87:40a866763f732373a207e65cbe71b50e",uri="sip:det*****now.my3cx.us:5060",response="51ac9db1345c32f9b232d623bc4e4ea7",algorithm=MD5
User-Agent: Yealink W60B 77.83.0.85 805ec0d8f6e4
Allow-Events: talk, hold, conference, refer, check-sync
Content-Length: 0
01/25/2022 3:29:12 PM - CSTA: on info success: CSTA Recv 200/INFO from 68.**.**.129:5060 tid=a1d63219b27d0721 Call-ID=V0kzWZhCNAwym3cK3XQUOQ..:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 104.***.**.212:5060;branch=z9hG4bK-524287-1---a1d63219b27d0721;rport=5060
CSeq: 33817 INFO
Content-Length: 235
01/25/2022 3:29:12 PM - CSTA: on info success: CSTA Recv 200/INFO from 68.**.**.129:5066 tid=35edc94b365f191d Call-ID=9GLbPRLZ3yZLFVbXN4K_GQ..:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 104.***.**.212:5060;branch=z9hG4bK-524287-1---35edc94b365f191d;rport=5060
Contact: sip:2000@68.**.**.129:5066
To: sip:2000@68.**.**.129:5066;tag=2277290676
Call-ID: 9GLbPRLZ3yZLFVbXN4K_GQ..
CSeq: 33817 INFO
User-Agent: Yealink SIP-T46S 66.84.0.125 805ec0cb8a32
Content-Length: 235
01/25/2022 3:29:12 PM - CSTA: onReadyToSend: CSTA Send Req INFO from 0.0.0.0:0 tid=0260ce27a2d87505 Call-ID=9GLbPRLZ3yZLFVbXN4K_GQ..:
INFO sip:2000@68.**.**.129:5066 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---0260ce27a2d87505;rport
Max-Forwards: 70
Contact: sip:2000@104.***.**.212:5060
CSeq: 33817 INFO
Content-Length: 216
01/25/2022 3:29:12 PM - CSTA: onReadyToSend: CSTA Send Req INFO from 0.0.0.0:0 tid=71146632809de023 Call-ID=V0kzWZhCNAwym3cK3XQUOQ..:
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---71146632809de023;rport
Max-Forwards: 70
CSeq: 33817 INFO
Content-Length: 216
01/25/2022 3:29:12 PM - Default best-route IP is determined as 104.131.53.212
01/25/2022 3:29:08 PM - ~Target=Unknown:+158******04@(Ln.10002@Det******************ply)
01/25/2022 3:29:08 PM - Leg L:729.1[Line:10002<<+184******29] is terminated: Cause: BYE from PBX
01/25/2022 3:29:08 PM - Terminated from "TOLL FREE CALL" sip:+184******29@det**********ape.pstn.twilio.com;tag=93281822_c3356d0b_f8330996-1a5e-42d4-888c-0ec2d0a2929d to sip:+131******69@det*****now.my3cx.us;tag=0002436c; reason: Rejected
01/25/2022 3:29:08 PM - L:729.1[Line:10002<<+184******29] Sending: OnSendResp Send 403/INVITE from 0.0.0.0:0 tid=242b.b073beed63db7feda974ba954bb9d9a7.0 [email protected]:
SIP/2.0 403 Forbidden
Via: SIP/2.0/UDP 54.***.**.0:5060;branch=z9hG4bK242b.b073beed63db7feda974ba954bb9d9a7.0
Via: SIP/2.0/UDP 172.**.**.89:5060;rport=5060;branch=z9hG4bKf8330996-1a5e-42d4-888c-0ec2d0a2929d_c3356d0b_53-10503659749058265828
To: sip:+131******69@det*****now.my3cx.us;tag=0002436c
From: "TOLL FREE CALL" sip:+184******29@det**********ape.pstn.twilio.com;tag=93281822_c3356d0b_f8330996-1a5e-42d4-888c-0ec2d0a2929d
CSeq: 1 INVITE
Warning: 499 JXMWZ-LD3R4-NMBCO-BZVYH-3ASPX.localdomain "Forbidden"
Content-Length: 0
01/25/2022 3:29:08 PM - SendMsg from sip:+131******69@det*****now.my3cx.us;tag=0002436c to "TOLL FREE CALL" sip:+184******29@det**********ape.pstn.twilio.com;tag=93281822_c3356d0b_f8330996-1a5e-42d4-888c-0ec2d0a2929d
01/25/2022 3:29:08 PM - Call(C:729) is terminated
01/25/2022 3:29:08 PM - [CM503020]: Call(C:729): Normal call termination. Call originator: Line:10002<<+184******29. Reason: Forbidden
01/25/2022 3:29:08 PM - [CM503016]: Call(C:729): Attempt to reach sip:7669@104.***.**.212:5060 from Line:10002<<+184******29 has failed. Reason: Forbidden
01/25/2022 3:29:08 PM - [Flow] Current call diversion path:[]
01/25/2022 3:29:08 PM - L:729.1[Line:10002<<+184******29] failed to reach Line:10002>>+158******04, reason Forbidden
01/25/2022 3:29:08 PM - RerouteReq
01/25/2022 3:29:08 PM - Leg L:729.2[Line:10002>>+158******04] is terminated: Cause: 403 Forbidden/INVITE from 54.***.**.3:5060
01/25/2022 3:29:08 PM - L:729.2[Line:10002>>+158******04] got Terminated Recv 403/INVITE from 54.***.**.3:5060 tid=237a7875044feb28 Call-ID=QoDXAZzAPTpSt27So0xZfA..:
Via: SIP/2.0/UDP 104.***.**.212:5060;received=104.131.53.212;branch=z9hG4bK-524287-1---237a7875044feb28;rport=5060
Contact: sip:172.**.**.250:5060
To: sip:+158******04@det**********ape.sip.twilio.com:5060;tag=72763472_c3356d0b_275732f1-fdb1-4ae1-8bb1-cf9fc3c66c3d
From: "Det***********ape" sip:+184******29@det**********ape.sip.twilio.com:5060;tag=18132c1e
Call-ID: QoDXAZzAPTpSt27So0xZfA..
CSeq: 1 INVITE
Server: Twilio
Content-Length: 0
01/25/2022 3:29:08 PM - Terminated from sip:+158******04@det**********ape.sip.twilio.com:5060;tag=72763472_c3356d0b_275732f1-fdb1-4ae1-8bb1-cf9fc3c66c3d to "Det***********ape" sip:+184******29@det**********ape.sip.twilio.com:5060;tag=18132c1e; reason: Error
01/25/2022 3:29:08 PM - Call to T:Line:10002>>+158******04@[Dev:sip:10002@det**********ape.sip.twilio.com:5060] from L:729.1[Line:10002<<+184******29] failed, cause: Cause: 403 Forbidden/INVITE from 54.***.**.3:5060
01/25/2022 3:29:08 PM - L:729.2[Line:10002>>+158******04] got Failure: Failure Recv 403/INVITE from 54.***.**.3:5060 tid=237a7875044feb28 Call-ID=QoDXAZzAPTpSt27So0xZfA..:
CSeq: 1 INVITE
Server: Twilio
Content-Length: 0
01/25/2022 3:29:08 PM - [CM503003]: Call(C:729): Call to sip:+158******04@det**********ape.sip.twilio.com:5060 has failed; Cause: 403 Forbidden/INVITE from 54.***.**.3:5060
01/25/2022 3:29:08 PM - Session 1537933 has failed in leg L:729.2[Line:10002>>+158******04] ; Cause: 403 Forbidden/INVITE from 54.***.**.3:5060
01/25/2022 3:29:08 PM - Failure from sip:+158******04@det**********ape.sip.twilio.com:5060;tag=72763472_c3356d0b_275732f1-fdb1-4ae1-8bb1-cf9fc3c66c3d to "Det***********ape" sip:+184******29@det**********ape.sip.twilio.com:5060;tag=18132c1e
01/25/2022 3:29:08 PM - [CM503025]: Call(C:729): Calling T:Line:10002>>+158******04@[Dev:sip:10002@det**********ape.sip.twilio.com:5060] for L:729.1[Line:10002<<+184******29]
01/25/2022 3:29:08 PM - Route to L:729.2[Line:10002>>+158******04] sends Invite-OUT Send Req INVITE from 54.***.**.3:5060 tid=237a7875044feb28 Call-ID=QoDXAZzAPTpSt27So0xZfA..:
INVITE sip:+158******04@det**********ape.pstn.twilio.com SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---237a7875044feb28;rport
Max-Forwards: 70
Contact: sip:det**********cape@104.***.**.212:5060
From: "Det***********ape"sip:+184******29@det**********ape.sip.twilio.com:5060;tag=18132c1e
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE, UPDATE
Supported: replaces, timer
User-Agent: 3CXPhoneSystem 18.0.2.314 (314)
P-Asserted-Identity: sip:+184******29@det**********ape.sip.twilio.com:5060
Remote-Party-ID: sip:+184******29@det**********ape.sip.twilio.com:5060;party=calling
Content-Length: 222[/ICODE]
My settings are exactly the same with the ones applied when you use the default template to set up your trunk.
Also 302 diversion is not supported for Twilio trunks so I would not waste any more time testing that.
Have a look at this reply and test it with these settings. It won't keep the originator caller ID when forwarding a call but it will help us pin point the issue. Let us know if that works for you.
Hi @YiannisH_3CX
Good news -- it works now. I contacted Twilio support, explained the issue I was having, and gave them the same information which I posted here. The Twilio support agent explained that by default, Twilio will not allow outbound calls ("forwarding") from a phone number that has not been verified with them. They understood my situation and because the calls I would need to forward could come from any number, they activated a special flag on my account which allows unverified numbers to be forwarded through their service.
Thank you for your help as well. Is there a way to mark this thread as "solved" so that it may help others at a later time?
Glad to see the issue has been resolved and thank you for the update. We will make the necessary adjustments on our side as well.
Marking this as Solved.
Reactions: DavidM84
lastshadow
