Problem removing trunks
Amphibian
Hey Team,
Elastix Version 2.5.0.1
Had four sip station trunks, modified trunks and found that the modify didn't take effect. So I removed the trunks, figuring it would remove what had been programmed in....no dice. If I dial the Sip station numbers I had removed from the server they still ring at the original extension they were first assigned to. Even though when you do a "Sip Show Peers" and the return does not show the sip station peers they are in fact still on the server and registered...
Where are they store so I can remove them manually as I am not finding them? Was/is this a bug that was found that I haven't learned about?
I went to the putty and did a cmd line "yum update" and it returns no files marked for update....
I knew I should have stuck with 2.4 as I had no problems with it.....
amphibian
