Problem upgrading 18 to 20
pscs
SOHO User
After a disastrous attempt to upgrade v18 to v20 last year, I thought I'd try again. Even though v18 is working perfectly, it feels like I'm being pushed to upgrade to v20.
This time it gives up rather than doing a bad upgrade, which I suppose is an improvement.
The first 'fail' I find in the log file I get emailed is
Reading package lists...
[33m====== [11:29:30] Preparation: Upgreadability status seems OK[39m
[33m====== [11:29:30] Preparation: Checking locales[39m
[33m====== [11:29:30] Workaround: Unholding packages to avoid issues during the upgrade[39m
[33m====== [11:29:30] Upgrade Result: *******************************************[39m
"result": "aborted",
"time": "28-01-2025 11:29:30",
"title": "File ownership problem",
"message": "There are files under /var/lib/3cxpbx/Bin/nginx/conf with the wrong user and/or group ownership. Please make sure the files are owner by the user: phonesystem"
[31m[11:29] aborted: File ownership problem - 0[39m
So, that's complaining about a 'file ownership' problem. If I ssh onto the server and look in that directory, everything looks OK:
root@3cx:/# cd /var/lib/3cxpbx/Bin/nginx/conf/
root@3cx:/var/lib/3cxpbx/Bin/nginx/conf# ls -la
total 32
drwxr-xr-x 4 phonesystem phonesystem 4096 Jan 26 04:00 .
drwxr-xr-x 3 phonesystem phonesystem 4096 Dec 17 2021 ..
drwxr-xr-x 3 phonesystem phonesystem 4096 Dec 3 10:48 Instance1
-rw-r--r-- 1 phonesystem phonesystem 1647 Nov 13 09:05 lets-encrypt-x3-cross-signed.pem
-rw-r--r-- 1 phonesystem phonesystem 5910 Jan 26 04:00 nginx.conf
-rw-r--r-- 1 phonesystem phonesystem 812 Nov 13 09:05 shared-headers.conf
drwxr-xr-x 2 phonesystem phonesystem 4096 Jan 26 04:00 snippets
Any ideas?
As the upgrade process seems a bit flaky, is it possible to do a fresh install of v20 and copy my configuration into it?
Yes, it is possible to just backup your machine and restore to Version 20. This is the exact same procedure that is used in a Windows environment.
@pscs Did you check in all the subdirectories?
x1515
