Solved Problem with calling by name
decibell.ca
I have a servers with V16 when a use the function dial by name it's working great
when I did an upgrade from V16 to V18 with the same server when I use the same function call by name as soon i press the option number I will receive and error FILE NOT FOUND
Please any help!
Joe
Update your prompts.
Settings > System Prompts > Updates, choose your languages and update them.
Reactions: Vali_3CX
It's working!!!
Thank you very much for your help, I appreciated :)
they changed and add options
thanks again
Please can you send the command line code for V18? to use with SSH?
thanks
thanks
There's no command line to do this. Only through the 3CX Management Console.
if where i have my servers do not have 3CX in there list how can we install?
You can use the 3CX Debian ISO which makes it easy, if the provider supports custom ISOs.
Otherwise, just get a supported provider or one that supports custom ISOs, if not you end up with an unsupported instance.
they do not have custom IOS
Thanks again for your help
apbGroup
