Solved Problem with Digital Receptionist
CRAFSL
We have an issue that has started recently with calls going through our digital receptionist not recognising any numbers dialled so it plays through the whole message before transferring to the reception handset.
After further testing we have narrowed it down further to it only affecting iPhones on 4g on one mobile provider network if we drop the mobile connection to 3g it works. If we leave 4g on and turn VoLTE off it works.
If we ring a different SIP trunk they all work.
We have tested with Android on the same network on both 3g and 4g and it works ok.
The network provider has told us the following
"The problem seems to be in the negotiation of codecs. The customer 3CX is replying with a different rate for the audio than they use for the event. In order to have DTMF detected it is mandatory to have both in the same rate."'
Is this possible to change on the 3CX system or are they talking rubbish and I need to go back and escalate to their support team?
Just looked at our settings and the only difference was the Support Reinvites being checked on the SIP trunk options. Removed this and it now works.
Hi @CRAFSL,
Who is the provider that you're using? It may well be a codec issue but we'll have to take a closer look to be sure.
Working now I had to uncheck the Support Reinvites option on the "faulty" SIP trunk.
Just strange it happened on iphones on 4g with VoLTE and only with with one mobile provider. The same telco provided the SIP trunk and is the mobile carrier with the problem.
Reactions: VasilisV_3CX
Interesting! Thanks for sharing. Glad you've resolved this. If you require any further assistance, feel free to open a new thread @CRAFSL.
lastshadow
