Problem with last update, making call
Achille F
Hi all! From the last update some of my users, only when they make a call, android call app goes over the 3cx app, as in the video that I attach. Could you help me? Thanks a lot
Calling problem
Achille
Hi Achille!
First, could you please go to Settings --> Advanced and here, check the "Car/Bluetooth support (Telecom API)".
If it is checked, uncheck it and try again.
If it is unchecked, check it and try again.
Also, could you please tell us the make/model your device is and what Android version it is running?
Hi thanks a lot for your kindly answer! It works now! Unflagged it and works
We are using Ulefone Armor X8 with Android V10, kernel 4.9.190
Reactions: NickD_3CX
That's great! Unfortunately not all Android phones support the Telecom API, so in come cases it needs to be unchecked
Stephan Eusebe
