Problem with new Plugin 9.1
FedericoRELCO
Wizard doesn't work and on developer of Chrome I can see this error:
Uncaught TypeError: Cannot read property 'split' of undefined
at HTMLFieldSetElement.<anonymous> (activation_wizard.js?ver=9.1.0:141)
at Function.each (load-scripts.php?c=0&load[chunk_0]=jquery-core&ver=5.5.1:2)
at n.fn.init.each (load-scripts.php?c=0&load[chunk_0]=jquery-core&ver=5.5.1:2)
at HTMLInputElement.<anonymous> (activation_wizard.js?ver=9.1.0:140)
at HTMLInputElement.dispatch (load-scripts.php?c=0&load[chunk_0]=jquery-core&ver=5.5.1:3)
at HTMLInputElement.r.handle (load-scripts.php?c=0&load[chunk_0]=jquery-core&ver=5.5.1:3)
Hello @FedericoRELCO,
Did you try to uninstall and re-install the plugin and the experience is the same?
The following exception is shown immediately, or after some configuration steps.
@Constantinos Constantinou I can confirm the same issue. the plugin settings will "work" initially, once we put in the pbx settings into the plugin for we are no longer able to access the settings as it will load to a blank screen.
when we load the f12 dev menu we get a similar error as the OP
I'm using the edge browser 86.0.622.51. same issue occurs in chrome as well.
Reinstalling the plugin no change
older plugins work aside from the business hours saving issue
Uncaught TypeError: Cannot read property 'nodeName' of undefined
at L (jquery.js?ver=1.12.4-wp:2)
at Q (jquery.js?ver=1.12.4-wp:3)
at Function.data (jquery.js?ver=1.12.4-wp:3)
at n.fn.init.rules (jquery.validate.min.js?ver=1.13.1:4)
at setChannelValidationRules (settings.js?ver=9.1.0:350)
at wplc_changeChannel (settings.js?ver=9.1.0:197)
at HTMLDocument.<anonymous> (settings.js?ver=9.1.0:25)
at i (jquery.js?ver=1.12.4-wp:2)
at Object.fireWith [as resolveWith] (jquery.js?ver=1.12.4-wp:2)
at Function.ready (jquery.js?ver=1.12.4-wp:2)
Running Ubuntu server 20.04 with the latest updates for wordpress as well as the OS
Same problem here as from version 9.1 : Settings page is blank.
"Uncaught TypeError: Cannot read property 'nodeName' of undefined "
Tried uninstall/install plugin : no solution; same problem.
Without being able to enter setting, the plugin is useless.
Any help/suggestions?
Hello @Peter Wouters ,
I've just sent you a personal message in regards to an internal build that we might give it a try if you would like.
Thank you.
Thank you @Peter Wouters for your input. It seems that the issue is fixed on our internal build.
We are planning to release a build during the days, so stay tuned.
Reactions: FridayIT
Stephan Eusebe
