Problem with Secure SIP
Alphabetic
3CX MVP
I've found that if you uncheck the "Secure SIP/TLS" and Press OK then cancel the confirmation to restart the server, the certificate disappears and will not come back.
The only way I can get this back in is by doing a reinstallation and restore of my PBX.
Is there an easy way to get this back?
it's a 3CX SSL.
Now I cant even take a backup to restore...
Code:
3CX Phone System tried to backup but failed due to the following reason(s):
System.Xml.XmlException: Root element is missing.
   at System.Xml.XmlTextReaderImpl.Throw(Exception e)
   at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
   at System.Xml.XmlTextReaderImpl.Read()
   at System.Xml.Linq.XContainer.ReadContentFrom(XmlReader r)
   at System.Xml.Linq.XContainer.ReadContentFrom(XmlReader r, LoadOptions o)
   at System.Xml.Linq.XDocument.Load(XmlReader reader, LoadOptions options)
   at System.Xml.Linq.XDocument.Parse(String text, LoadOptions options)
   at TCX.Configuration.GroupMembersSerializerAttribute.<>c.<Serialize>b__0_0(GroupMember x)
   at System.Linq.Enumerable.SelectArrayIterator`2.MoveNext()
   at System.Xml.Linq.XContainer.AddContentSkipNotify(Object content)
   at TCX.Configuration.GroupMembersSerializerAttribute.Serialize(Object o, PropertyInfo p)
   at TCX.Configuration.SerializationExtension.SerializeObject(IOMSnapshot obj, Context context, IOMSnapshot owner, PropertyInfo p)
   at TCX.Configuration.DefaultSerializationAttribute.Serialize(Object owner, PropertyInfo p)
   at _3cxNetBackupAndRestore.BackupTasks.BackupOMTask.BackupOM(BaseTask task)
   at _3cxNetManagement.BaseTask.Run()
hughesdouglas
