Solved problems Snom M700 after upgrade to V16
JVM-tech
I have an installation where the customer complains about his outgoing phones on the portable snom M65. Before everithing was fine. After i did the upgrade from V15 to V16 he started to complain. To make is more complicated.
what works:
- all cals from the standard snom phones lik D715
- all incomming phone calls from outside or inside to the M65 phones.
- all outgoing intern calls inside between M65 or M65 to D715.
What not works:
- outgoing calls from M65 to outside numbers. It takes a will and than it gives 2 tones and disconnect.
Before and after the update the config of the 3cx is never changed. Te config is even for 3 years never changed.
So my first gues was to reboot the M700. I tried to reach it but the passwod dos not work. wierd because it is correct. I did had dis before also after a reconfig and update it was ok. Now again the same. It looks that it vorget the config. So i searchd after th provision file on the 3cx to retrieve to hope to retrieve the password in the file..... it looks that i cant find the provisionfile ??
Any idea ?? Extra info this is a multicell M700 enviroment. On a second site it looks that i have the same problem to acces the M700.
What firmware is the M700 and the M65 running?
So far I can see in the 3cx webinterface “03.55.0021”. I know that this is a installation from 2 years ago. Than I followed exactly the 3cx Manual. 3 Months ago. I did reset the hole Dects settings and starten over again. This was due a m700 that was broken. The same problem. I Could not acces the main M700. Somhow the password was not Working.
I will try to factory default and look for the latest adviced firmware. It is just a difficult period with the COVID-19 to enter this shop location. I will keep you posted
This is now resolved. A full reset and upgrade to the latest firmware of the dects was the solution. I supose that the previos firmware is not compatible with the new 3cx software version.
Reactions: JohnS_3CX
