- Joined
- Jul 3, 2017
- Messages
- 184
- Reaction score
- 12
Ever since we migrated to 3cx we are having issues with DTMF.
Our door phone is using RFC2833 in order to accept incoming DTMFs, so that local extensions can open the door by pressing a DTMF sequence.
However, our provider is using inband.
We have thus configured our local extensions to use inband, in order to be able to handle our customer's IVRs when they make outbound calls to PSTN, thus when using our SIP provider.
However, our local extensions can no longer open our local doorphone.
As far as I know,3cx only supports DTMF relay, i.e. it relays the DTMFs as received by the extension. It does not support DTMF interworking, i.e. translating from RFC2833 to inband and vice versa.
Since our provider uses a different method than our door phone, what is the solution we could have in our environment so that both can work?
Thank you in advance,
George
George
