Profile user
luc.jubeau
Platinum Partner
Which profile a user should be to have statistics and record of his queues ?
What do we have to setup for this ?
Thanks for your answers,
Luc
You may check extension roles guideline here for further information.
i've checked roles guideline. i've given group owner role to my user.
However, when i've opened my webclient. i've no queues while my user is in two queues. Why ? and what have i to do ?
Best regards,
Luc
Just to clarify, you want to generate reports or to see the Queue Panel?
When my user want to see reports. He goes to admin (1) > Reports (2) and chooses one topics (3)
But he has got this
He is in two Queues.
Can you assign the manager role to this extension and check?
Yes we have had the same result. And in the role guideline, Manager rights are less than owner
Can you please check if all the queues have an assigned department?
If not can you set them to the Default departments and check again?
i'm not sure but i've seen that there is no queue in that page :
however, in the manager interface my user is in queues
i'haven't seen where i could assigned a department to my queue
Can you please login with System Owner first and make the adjustments?
yes i've just tried and tha doesn't work.
to be sure, i've used my system owner extension to adjust the group owner extension. Is that what i have had to do ?
Access with System Owner and check if all the Queues have assigned departments.
I'm very sorry. This is The issue. No queue have got a group membership but where could I assign a group to a queue?
i don't see.
Try to edit the queue and set the department:
Yes if iedit a new queue, i have this option to assign a group to a queue.
But, if a queue exists before, i can't. How could i do ?
I would suggest that you recreate the queue and ensure that the Department is assigned.
There is no possibility to modify an existing queue because i have 40 queues and i don't want to recreate all :)
Senergia
