Prompt Sets & Services
Alphabetic
3CX MVP
Hello!
Is there a way to identify a custom prompt set from the ID?
And which service(s) do I need to restart for it to apply?
thanks.
The build in prompt set IDs are published here:
https://www.3cx.com/docs/localize-promptsets/?utm_source=chatbot&utm_medium=referral
A prompt set with a different ID would be a custom one (and if the instructions for creating it were followed, it should have a distinct and clear name too).
Applying it is simply choosing it as the System->System prompt for global, or within a Departments option for more limited scope (By default departments follow the global setting).
Thanks :) I was able to find the name now
Reactions: KyriacosS_3CX
DrunkeMeister
