Solved Proper way of changing recording directory
JCubio
Hi Experts,
I have problem with changing the recordings from another directory.
I added another disk and created a folder named Recordings.
13896
When upon changing. I also copy all recordings from default directory.
But the problem is when new calls are made the recordings are not saved but there is a record but when I try to play it. it says file not found
13897
Basically the recordings are not created in the new directory.
When I changed it again to default it works.
Hi all,
This is solved.
Issue is with folder permission.
Hi JCubio
The user phonesystem needs to be able to read and write to the folder.
I'm glad you already figured it out ;)
Kayla Norris
