Proper way to "unregister" a SIP Trunk from Pro
texmansru47
SOHO User
Good Morning,
Where can I find the proper way to remove a registered Voxtelesys SIP trunk from my PRO Account?
Texmansru47
Just delete the trunk... in the (...) menu on the right.
Reactions: GregG_3CX
not sure op wants to delete the trunk, but related to its title more a way to only unregister ?
Navigate to your trunks Options menu. Deselect the options "Allow inbound calls" and "Allow Outbound calls". This will unregister the trunk. You can also delete it as previously mentioned if you do not want to keep it. The PBX will unregister the trunk from the provider upon deletion.
SG_F7
