Purge old *.3cx.us domain names
GordonShumway
Forum User
I've ran a few free instances in the cloud in the past and used various .3cx.us domain names requested during the setup/config wizard. Is it possible to request to purge two of them I'd like to re-use for the new instances? Do they get auto-purged after some time? How long? How can I check if they're available again without installing a new instance?
Thanks!
Thanks!
When setting it up with PBX Express, you will have an email containing Customer Portal credentials.
Use these to login into 3CX Portal and under Keys, select the key then click Release FQDN. An hour or so afterwards, the FQDN will be available.
If you did what I think you did, you will need to login into each individual account to release each FQDN.
Reactions: GordonShumway
jmarshall
