PWA in terminal Server environment
MarcV
We have a customer using PWA in a terminal Server environment on 3CX Hosted V20 update 9. It worked correctly for about 1,5 years now and since last week it is not working anymore. At first they saw "Disconnected. Reconnecting in x sec" at the bottom of the screen, and this kept reconnecting. Now they only see a black screen (like it is trying to load the page, see attached file).
Anyone has any idea what could cause this? If i connect at our office on that 3CX system on my own system (no terminal server) it works correctly. There are no blacklisted IP addresses in the 3CX.
I can see that you opened a ticket for this, and we will respond to you and check there.
If you run a traffic sniffer on the terminal server, you should see the PWA trying to connect after starting it up. That should already give you some hints as to what might be happening.
Have you introduced any restrictions?
what browser are you using?
