PWA is ignoring Soundcard settings
marcoeble
the last PWA Client for Windows is ignoring the Audio Settings. It is using the Default Output Device. But the Microphone is correkt.
Reinstall or Reconnecting the Headset does not solve the Problem.
Did anyone has that Problem?
Yes, having the same problem here. We're planning on switching back to the old client as we've lost confidence in the PWA. Too many issues with audio and call transferring.
Good luck switching back... the MSI has been removed on the latest PBX build.
Legacy Windows app and the desktop app are available. Access to the webclient and go to apps, from there you can download and provisioning both the legacy or desktop app.
We push out all apps via an endpoint management solution, so distributing the installer isn't an issue. Far better from that perspective than the newer app which can't be centrally deployed, nor does it make adding firewall rules straightforward for users without admin access.
AshleyStokes
