QR codes printing
DDave
Forum User
Hello, i've got about 30 QR codes i need to give to my clients for provisioning on their phones and i wanted to know if there was a quick method to print them out and give them, otherwise i'd just screenshot the qr's and manually give them out which looks kinda lame. Either this or i print the extension's provision page which i don't want to do because shows unnecessary data to them.
Thank you
You just have to enter the mail adress in each extension and then all users will receive their own QR and stuff
Hi , as Mathieu said, welcome email with all credentials (iincluding QR) and getting started pdf are sent if in each extension you set email adress for each user
Hi Dave,
You will either have to screenshot them, or use the Welcome email.
The welcome email can be customized by the way so you can remove any data you consider unnecessary for your users.
If you do a search on-line, you will find a number of QR generators. These allow a drag and drop, to create a printable QR code.
I resolved manually taking a screenshot of each qr codes with extension info, thanks
[email protected].
