Solved QrCode doesn't appears in the Email Invite 3CX
Ricardo Ripritec
Intermediate Cert.
Lately every email invite sent in the various 3CX Instances doesn't appears in the attached files in the email.
I tried in many providers too and the file QrCode is not sent.
Anyone knows if lately the QrCode file isn't sent in the email invitation ?
Hi Ricardo,
To which email that you sent a Welcome email invite?
In case this helps, can you try a Gmail account to send a Welcome email?
Default 3CX, but I'll try the anothers and report.
Thxs
hi,
What is your PBX server (Linux or Windows) and version?
Hi , Linux Debian 9 on Azure
Version 16.8.9
And Debian 10 Version 18 I've made some tests and in the ICloud on Iphone the QrCode is attached. Ithink the problem is the Outlook - Office 365 restritions
Hi @Ricardo Ripritec,
To clarify, which SMTP server are you sending email from? You can check this in Settings >> Email. Are you using the Office365 option?
Hi I've been using the native 3CX settings
Assuming you are on the latest Update of 3CX, so most likely V16 Update 8, what do you see in the Welcome Email that you receive?
It should look something like this:
Don't you see anything in the location that I have highlighted?
Ok now is inserted in the body email , sorry for the inconvenience thanks so much.
Best Regards
Glad to hear that you've found the QR code. If you require any further assistance, feel free to open a new thread!
Reactions: Ricardo Ripritec
megalmazan
