Question about 3cx hosted on local pc
zamp
New User
I want to know when trial pro version expires , the local 3cx will eventually stop working or it will change version?
I think it's 40 or 60 days. It should stop working for a recently setup trial (versions from last year may revert to a free version with it's limits)
so new trial keys will totaly stop working after 60days and will not revert to free version. I ask cause i need local sip trunk from my provider and i cant do it with any cloud version cause needs my internet connection.
Correct (unless it's 40 days, I don't remember). No free version anymore, use 3CX FREE (the former StartUP FREE)
i have unsupported trunk provider and i cant :S
Then for a whole $12.08 per month, you can buy 3CX pro
Alternatively you might be suited with another product like Asterisk
mazet
