question on 3CX route descision making and failure
[email protected]
My question is related to Outbound rules.
If I have 2 seperate routes for the same dial patern (route1 via 1 carrier, route2 via carrier 2). how would the call route using the second carrier? Is there specific SIP messages that the 3CX needs to receive before it sends the call to the second route?
The reason I need this info is to test failure scenarios, but first I need to know in what failure scenario (SIP Messages) will the 3CX use the next available route so to test proper failover of routes.
Also, is there a log file I can look at to see what/how the 3CX is making the inbound and outbound routing descision?
3CX rules normally go in a top down (waterfall) type fashion - if the first does not work then it will move onto the second. However within an outbound rules you have failover options if the 1st, 2nd, etc route does not work.
If you have 2 matching rules for ITSP 1 and 2 why not simply create one single rule and have router 1 as ITSP 1 and ITSP 2 as the second. I would suggest having a read of this: https://www.3cx.com/docs/manual/sip-trunks/
yes that is what I am doing. The question is what SIP message does the 3CX require to get in order to consider that first route invalid and try the second route?
I cannot clarify 100% so would probably wait for a member of 3CX staff to response, however from my experience it is normally something like a "503 Service Unavailable" message from the provide that would say the link is down.
It certainly would not do it on registration timers as you could be using an IP authenticated SIP trunk.
exactly, but in my case the trunk is to a Oracle Session Boarder controller at the datacenter, the second route is another boarder controller in a differente location. So in case the one boarder controller is either not responding, or the carrier tied to it fails, then it should try the seconde controller.
found the answer:
https://www.3cx.com/docs/multiple-outbound-call-routes/
List of SIP answers causing a switch to route 2-5:
Code:
400 Bad Request
401 Unauthorized
402 Payment Required
403 Forbidden
404 Not Found
405 Method Not Allowed
406 Not Acceptable
407 Proxy Authentication Required
408 Request Timeout
409 Conflict
410 Gone
411 Length Required
413 Request Entity too large
414 Request URI too long
415 Unsupported Media Type
416 Unsupported URI Scheme
420 Bad Extension
421 Extension Required
423 Interval too brief
433 Anonymity Disallowed
480 Temp Unavailable
481 Call Transaction does not exist
482 Loop Detected
483 Too many hops
484 Address Incomplete
485 Ambiguos
487 Request Terminated
500 Server Internal Error
501 Not Implemented
502 Bad Gateway
504 Server Timeout
505 Version Not Supported
513 Message Too Large
603 Decline
604 Does not exist anywhere
606 Not Acceptable
gmacinit
