Solved Question on Call Logs
pseubring
Tracking down a call in our logs when I saw the below entry. Can someone explain why the call is showing as going to PBX instead of to my normal IVR? I also haven't seen the text and ":" before the from number.
02/03/2021 3:40:47 PM:Color Call (+18126164777)PBXNot Answered
Running Pro ver 16.0.655 on Windows Server
thanks for any insight you can provide
Is this happening often, or a one-off?
Does the call routing always send callers direct to the IVR?
If a caller does hang up, does it show IVR instead? Answered, or Not Answered?
Could it be that the caller hung up very quickly (half a ring)? Have you tried to replicate this?
We get 3 to 5 of these calls per day. All of our numbers/DIDs either go to an IVR or direct to an extension. These calls always shoe Not Answered. I do not know how to replicate a call so that it shows as PBX in the To field of the logs.
If you happen to catch it next time, you might check the 3CX Activity Log, and find the log of the call, to see what actually happened to it.
I dont see anything in the activity log but I did figure out what is happening. I have an inbound rule on a DID that is set to End Call instead of routing it to an IVR. thanks for the help everyone!
Reactions: ChrisC_3CX
Kayla Norris
