Question regarding paging
RDWild
We have a system set up, with a mix of Fanvil X5U, X5U-V2, and a Yealink T57W for phones. We also have a paging group set up, that pages through speakers in the shop connected to a Fanvil PA3, and then through the speakers on the phones up front. The problem we have, is that if someone is on a call on the phones up front, and someone rings the paging group, it either puts their existing call on hold, or hangs up on them. Is there a way to have calls in progress take priority over the paging function?
This behavior is expected as Paging is mostly used for emergency purposes and active calls will on hold when paging is dialed.
so, no way to change this?
I have seen in the forum users that created custom templates to change the priority of the call however this is not supported from 3CX. An idea was this forum post.
Graham Robertson
