Solved Queue Manager question
cam
Hi, one of the items in the Queue Manager windows is 'Answered'
Does that mean how many calls the agent has answered that day, since they logged onto the queue or something else?
thanks
Hi Cam,
Under your call queue and the in advanced, at the bottom indicated when the stats will reset, that count will depend on the setting in there.
Regards
Michael
Reactions: cam
Since last reset of the queue stats as @diamond9 said:
Reactions: cam
would this effect the monthly call reporting?
No doesnt effect reporting just the wallboards
Reactions: cam
the settings are not configured on the call queues so I would expect the number of calls answered to be a lot higher that it is as it should never of reset
Could the Q manager of reset the queue?
I dont see a option manually from the webclient, only from within the management console, also if the system has restart this will reset the stats in there.
Reactions: cam
so, if we had a power outage the queue stats would reset
Yes from what i believe.
Reactions: cam
Great, thanks for yout help Diamond9 and JohnS
Great service again!
Reactions: JohnS_3CX
intoxtech
