Queue recordings
greychain
Gold Partner
Is there anyway I can list all call recordings by queue ID?
Hi @greychain,
Currently there is no way to list call recordings by queue ID.
Hi, You could setup a call report
Type: Call Reports
Destination: Extensions in range (Enter queue number)
This will give you the play button for each recording
Reactions: VasilisV_3CX
Thanks for the clarification
The call reports don't detail queue number only extension numbers so not really useful if the agents are in more than one queue.
As @diamond9 mentioned, the report can be used in this case. It does show the queue number followed by the extension that answered:
bunthoeun.may
