Solved Quick one.. Free version, how many SIP trunks?
david.catherall
Forum User
I should know the answer - I believe it's restricted to 1 SIP trunk for the 4 and 8 SC standard 'free'. Can anyone tell me different? I've hunted through the comparison and i'm either missing a glaringly obvious answer or the restriction is no longer there? I'm only used to Pro and Enterprise so apologies for this, I imagine, oft requested info.
I've a customer who needs 8SC standard but wants 3 SIP (so that 3 external calls can be made simultaneously).
Ta
Hello
I think there is not limit on sip trunks, but I my be mistaken
Just remember a one sip trunk can handle more than one active call. If you required separate numbers, you have DDI numbers associated with the main number.
Reactions: david.catherall
I've not heard of a limit on SIP trunks either. The simultaneous calls count includes internal and external.
At one time the free version did have a trunk limit, this was a few years ago, but no longer.
If you use a SIP provider you should have 1 registration and the trunk should support 3 simultaneous calls. You would not have 3 separate trunk registrations. The limit is having a registration for separate trunks so one for Provider A, Provider B, and Provider C.
No limit in current versions.
Indeed, you are only limited by the simultaneous calls, so feel free to make as many trunks as needed.
You can increase your license size later as needed.
Reactions: AVB-INDUSTRY
ICTSupport@bedfordgirlssc
