Random Anonymous Caller I.D.
GBC_James
3Cx V18.0 Update 8 (build 939) running on a Windows Server 2019 Standard box on prem.
I had a call today from a staff member who said a customer had complained that we hide our Caller ID, which we don't.
We do set our caller ID globally so that calls made form any and all extensions have the same ID which is our main reception desk number.
This is working just fine, I tested it. A Lot. Our caller id definatelt shows as our main reception number.
However, I then made a call to a colleague's mobile phone, and the Caller ID was indeed Anonymous! Whaaat???? o_O
So I called another colleague's mobile phone and it was ok, showing our main reception number.
Checking back with the original helpdesk call, the number called was not a mobile number, it was a land line.
So there seems to be at first glance a bit of randomness going on here, as in this isn't down to just mobile numbers, or a particular carrier.
And in 7 years we have never had this problem reported to us, so looks like it's a recent development.
Anuone have an idea what might be going on here?
James
From the PBX side in order to sent anonymous you need to use a dial code first. Also there is a possibility that it is sent from the outbound rule that this depends on whether the sip trunk provider supports this functionality.
I would suggest that you first check this with the provider.
Thanks for your quick reply TheodorosG_3CX
I have just had as look at our outbound rules and there is nothing unusual there that might be causing this,
I will check with Gamma, our sip provider to see if they can shed some light.
What puzzles me is that this is a small minority of calls, that don't seem to have a connecting factor.
I agree this does not seem to have a pattern here. You may contact Gamma to check and if this requires further troubleshooting you may open a ticket to the Support Team to investigate.
Jake_Southern
