Raspberry Pi v18 Update 4
shawm90
Gold Partner
I know that update 4 is not supported on Raspberry Pis. I am also aware that the recommended way forward is to switch them to SBCs and have 3cx host it. I am wondering if this is what people are generally doing or if there is another work around that someone has come across?
We hadn't been using Pis for 3CX because we set up VMs in our data center for our clients. So we've only used Pis for SBCs. Though the down side there is Pi doesn't support upgrading the OS so that sort of upgrade would be a reinstall.
If you still wanted to host 3CX on site, you could install 3CX in a Debian VM or a spare PC with the same IP address and restore 3CX from backup during the install.
3CX on an Intel NUC with Debian works like a charm.
Off lease tiny/mini/micro form factor PC with vPro management feature configured and enabled so we can remote control the bare metal using meshcommander. Use xcp-ng as a virtualization layer and run 3cx as a virtual machine. (makes it easy to snapshot during upgrades, fire up full image backups and such and abstracts the hardware to a point where you can easily restore the VM on another box)
For the cost of an offlease HP elitedesk 800 g3 or similar Lenovo or Dell box it is slightly more than cost of Pi after you add all the accessories though far more powerful and versatile. For a smaller office, the same VM host can do a few extra tasks depending on their needs if you shove extra RAM and HDD in it that can also be a small workgroup fileserver for a small office.
